Date/Time: Sat, 18 May 2024 15:40:52 +0000
VbP improvements
View Count: 812
[2015-02-13 17:05:45] |
joshtrader - Posts: 442 |
I really like what you guys are doing with VbP improvements. Some brief feedback: The "color code volume bars based on percent" is great. However, I don't know if 5 levels of granularity will do this improvement justice, though it is a good start. I would estimate that a minimum of 20 would be sufficient. People will either want to pick out a single color family (sorry, I am not a color expert so my terms are not "correct"), like blue, and will probably want to change the amount of white/black (the right slider in the color picker). Or, they may want to do a full rainbow from a warm color to a cool color. (see attached picture) You have a new setting that allows for hollow bars, outline only, or filled bars. This is very nice; I still think that as I mentioned last year sometime, that the "outline" mode would be visually more appealing as more of a "stair step" draw type, rather than what you currently have as a line going from one volume bar to the next. Either way, I think that the profile should have a line connecting the high and low, which the outline mode in SC does not currently have, so that the profile appears more complete, and that the boundaries are more clear. (see other attached picture) Thanks for your continued improvements, and I look forward to taking advantage of them as I'm sure many traders who rely on the profile will. Date Time Of Last Edit: 2015-02-13 17:11:36
2-13-2015 11-57-08 AM.png / V - Attached On 2015-02-13 17:05:39 UTC - Size: 7.88 KB - 480 views 2-13-2015 12-02-33 PM.png / V - Attached On 2015-02-13 17:05:43 UTC - Size: 2.9 KB - 444 views 2-13-2015 12-11-12 PM.png / V - Attached On 2015-02-13 17:11:34 UTC - Size: 3.04 KB - 437 views |
[2015-02-17 02:52:04] |
What you are describing here still is under development. And these requested changes have already been done.
