Date/Time: Fri, 02 Oct 2026 11:50:49 +0000
new customer download issue
View Count: 1609
| [2013-05-26 07:50:34] |
The TT FIX adapter you are connecting to is not available over the weekend and therefore you cannot access historical Intraday data. To prevent connection attempts, simply select File >> Disconnect. When you want to connect select File >> Connect to Data Feed. The best place to start is to go through the Getting Started page here: http://www.sierrachart.com/index.php?l=doc/doc_GettingStarted.php Sierra Chart does provide a lot of functionality, but it is straightforward to use. Should not be complicated. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
