Date/Time: Thu, 11 Dec 2025 05:55:38 +0000
OEC Historical Errors
View Count: 1975
| [2013-05-24 17:20:18] |
| WarriorTrader - Posts: 247 |
Hello, There are errors in the OEC historical data. The low of today is wrong. I included a picture pointing out two errors. The live data was OK. Thx, WT using 976 Date Time Of Last Edit: 2013-05-24 17:20:54
| [2013-05-24 18:16:24] |
We are noticing a problem with the historical data from OEC.
| [2013-05-24 18:28:28] |
Hello, Do you mean you are NOT seeing a problem? -WT |
| [2013-05-24 18:50:11] |
We are, however it is not easy to resolve. There is a problem with the historical data from OEC. It's not something we have control over.
