Date/Time: Mon, 29 Apr 2024 10:30:52 +0000
Second source for some charting symbols
View Count: 1978
[2013-03-26 02:53:24] |
Willson - Posts: 176 |
I have read the documentation on this and will use separate instance of SC. Need advice. I use IQfeed for all charts in many chartbooks. Using their symbol format @..#. I want to get a few symbols from an OEC account to use on the existing charts. All are intrady. What is smart way to do this? Regards |
[2013-03-26 23:24:45] |
We are not really sure what you are asking here. In any case, please refer to this page: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
