Date/Time: Tue, 21 May 2024 13:54:25 +0000
Reload of Echo Charts needed
View Count: 827
[2015-02-04 15:28:17] |
User67959 - Posts: 1 |
Because I changed the time-frame of three of my ECHO charts I am told I need to have them reloaded to my account. ( Echo 6 major pairs, Echo EURUSD & Echo XAU XAG). Please do so at your earliest convenience. Thank you.
[2015-02-04 16:34:15] |
We are not sure what is meant by Echo charts. This sounds like a custom Chartbook you are using. There is nothing we need to do on our side. If you want to re-download the data in the chart, select Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
