Date/Time: Sat, 18 May 2024 15:00:33 +0000
Move to new spreadsheets
View Count: 845
[2015-02-04 14:50:46] |
User23815 - Posts: 209 |
Is there a method to migrate from old to new spreadsheets or do the formulas have to be built from scratch? I looked on Support Board and it mentions migrating to another copy and has a link Multiple Services. But when I click on that link it just takes me to the same page and I did not see a link for Multiple Services, other than the one that I clicked on with the previous page. Thanks
[2015-02-05 04:25:33] |
When opening an "Old Spreadsheets" file in the version of Sierra Chart that supports New Spreadsheets, it will be converted but only the formulas and values will be copied.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-06 02:18:08
[2015-02-05 13:36:52] |
Where can I find the Multiple Services information. When I click the link on the Spreadsheets section it just takes me back to the Spreadsheets page. I see no link in the Table of Contents to Multiple Services. Please supply me a link to the information so I can begin to migrate to New Spreadsheets. Am I correct that you are going to be discontinuing Old Spreadsheet versions this month or next? Thanks
[2015-02-06 03:42:21] |
Here is the documentation for Multiple Services: Using Multiple Data and Trading Services at the Same Time Old Spreadsheets we foresee will continue to be available in the current versions of Sierra Chart probably until the end of May. And they will be available in older versions for 4 years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
