Date/Time: Tue, 21 May 2024 20:11:53 +0000
Chart Values/Crosshair configuration
View Count: 1313
[2015-02-04 14:38:53] |
User23815 - Posts: 209 |
How do I change the color of the small crosshair in charts. I found the full lines but not an adjustment for the crosshair when you click and deactivate the full chart crosshairs. I have a grey chart background and the full lines are black, but the small crosshair is grey and disappears when in the general chart background. Thanks
[2015-02-04 16:31:48] |
To whatever extent this is possible it can be done through the Windows Control Panel Mouse settings. Look at the Pointers tab in the Mouse settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-04 16:32:12
