Date/Time: Sat, 18 May 2024 16:55:00 +0000
Sierra Chart historical data
View Count: 867
[2015-02-04 11:06:09] |
User49478 - Posts: 8 |
I'm missing futures contracts on the AEX index. You only offer December, March, June and September, but it is a monthly contract. The one for February should be AEG15, but when I add it manually it is not recognized. Can you add each month to the feed? Thanks |
[2015-02-04 17:00:54] |
We need to set this up and it will be done before the end of the day. We will post here when it is done.
[2015-02-06 04:23:07] |
We got delayed with this but it is now done. Go to the chart that is missing data and select Edit >>Delete All Data and Download to get the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-06 17:31:21
