Date/Time: Tue, 21 May 2024 19:26:29 +0000
Dax DYH15 Numbers Bars Study showing double amount of traded contracts
View Count: 833
[2015-02-04 10:51:17] |
User86139 - Posts: 10 |
Hello, There is a problem with The Numbers Bars Study & Numbers Bars calculated Values Study which are showing exactly double the amount of traded contracts. I checked this against Eurex Web-site and a friend trading using IQ feed. I am using Sierra Data Exchange. Regards |
[2015-02-04 16:17:39] |
This has been solved and the existing historical data for earlier in the day on 2015-02-04 which has 2 times the volume, will be corrected after the close.
