Date/Time: Tue, 21 May 2024 16:24:47 +0000
Rithmic feed.
View Count: 843
[2015-02-03 23:58:52] |
2garin - Posts: 184 |
Good day support. Open chart, historical data loaded. On the chart at the opening of the footprint has missing data BID/ASK. How to fix the problem? |
[2015-02-04 02:13:32] |
This is normal for a feed?
[2015-02-04 03:34:23] |
10 to 15 minutes of missing bid volume and ask volume when connecting to Rithmic is a limitation. To solve this you need to use the Sierra Chart Real-Time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
