Date/Time: Tue, 21 May 2024 19:46:23 +0000
number bar + study / price overlay Graphics
View Count: 780
[2015-02-03 17:01:40] |
david koresh - Posts: 6 |
Hello there I work with a number bar + study / price overlay What it gives me is that the numbers are in the bar But I have a little problem and I hope you can help me The problem that the line of the bar is on the number And I want it to be between the numbers how can I fix it For example, I've included you pictures I would be happy if you could help me as soon as possible Thank you and Have a nice day |
The line on the number.png / V - Attached On 2015-02-03 17:00:00 UTC - Size: 88.69 KB - 328 views The line between the number.png / V - Attached On 2015-02-03 17:00:15 UTC - Size: 87.59 KB - 324 views |
[2015-02-03 18:44:41] |
There is not a solution to this.
