Date/Time: Wed, 22 May 2024 00:38:00 +0000
DOM error FXCM?
View Count: 791
[2015-02-03 08:44:22] |
EuropeanTrader - Posts: 290 |
Hi, see this http://www.sierrachart.com/image.php?l=1422952993275.png its the same on live acc ? |
[2015-02-03 09:20:48] |
What symbol is this?
[2015-02-03 09:38:04] |
Select Chart >> Chart Settings and make sure the Session Times cover the entire 24 hours of the day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-02-03 09:38:15
[2015-02-03 09:54:01] |
GER30
[2015-02-03 09:54:29] |
now it seems to work, dont know why maybe update had something to do with it |
[2015-02-19 08:09:25] |
Hi same problem again see this: |
