Date/Time: Fri, 20 May 2022 17:52:24 +0000
Using a remote
View Count: 1437
[2013-05-23 23:22:12] |
Ronin - Posts: 35 |
Hi, I configured some shortcuts on my remote controller - this one for example - http://www.geek.com/xyzimages/stories/reviewimages/logitech_s510/s510_001.jpg What I noticed is that the remote controller isn't applicable on Sierra Charts - for example if I press the maximize/minimize option on my controller it won't change anything on sierra but it will on other apps Is it blocked by default, do I need to enable this feature on sierra so that it will allow the remote to be active? Thank you |
[2013-05-23 23:39:37] |
This is outside the scope of our support.
[2013-05-24 00:14:16] |
Ronin - Posts: 35 |
Thank you, my question is not for the controller configuration, I'd just like to know whether there is something that disables the "external" devices/controller that I need to enable
[2013-05-24 00:33:48] |
No. Nothing like that.
