Date/Time: Tue, 21 May 2024 17:54:10 +0000
Market Replay
View Count: 1107
[2015-01-31 05:18:23] |
User38706 - Posts: 12 |
Hello, I am using market replay and it appear the 1 minute bar does not update until the minute is over. I am not sure if this is a norm or is it because I am using Interactive Broker data. Please advise. Thanks |
[2015-01-31 21:36:33] |
Refer to this section here: https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#Notes In the case of Interactive Brokers, to get complete detailed tick by tick historical Intraday data you will need the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-01 07:40:39] |
My settings for "intraday data storage time unit" is already one sec but the replay does not reflect that. Please advise how can I change the settings back to the data feed provided by this Sierra Chart trial?j thanks |
[2015-02-01 17:58:03] |
What is the symbol of the chart you are replaying? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-01 22:12:40] |
Hi, I am replaying YM.
[2015-02-02 05:03:18] |
Follow the instructions here for a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Since you are on a free trial which is equivalent to package 5, the historical Intraday data for YM other than the most recent 10 minutes, will come from the Sierra Chart server and 1 tick data is provided. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-02 05:32:52] |
How do I connect to the Sierra data feed? I am on the Interactive broker data now, and not sure how to change back to Sierra.
[2015-02-02 18:04:29] |
Use the Sierra Chart Historical Data Service. Here are the instructions: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-03 15:33:54] |
Thank you.. everything is working now.
[2015-02-03 18:13:00] |
One thing that we remembered is that Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds needs to be enabled when using Interactive Brokers to get data from the Sierra Chart Historical Data Service.
