Date/Time: Tue, 21 May 2024 17:39:09 +0000
Major problem in drawn volume profile in 1226, 1227
View Count: 942
[2015-01-30 03:54:40] |
joshtrader - Posts: 442 |
Draw a volume profile. Click to select and change the region -- it does not change. It looks like it's thinking there's two profiles there, or something. Can provide screenshot etc but just try it. Was not there 1224.
Date Time Of Last Edit: 2015-01-30 03:55:49
1-29-2015 10-54-46 PM.png / V - Attached On 2015-01-30 03:55:49 UTC - Size: 17.25 KB - 353 views |
[2015-01-30 07:49:30] |
We will check on this.
[2015-02-01 23:10:05] |
I hate to press on this, but this is one of the major features of package 5, the ability to draw and modify VbP's on the fly, and it's not working. I would roll back but OEC bug fix in 26/27 prevents me from doing so.
[2015-02-02 00:02:50] |
There was a misunderstanding with what you were describing. We had thought you were trying to change the Chart Region for the Volume by Price study and this is not supported. We now see what you are describing and we will take care of this. Although not likely until tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-02 23:32:50] |
Pawel_Szpak - Posts: 48 |
This has broken like this before actually. Josh - whilst cumbersome, you can still adjust the profiles in the meantime with right click -> volume profile settings -> start/end date time. tedious. |
[2015-02-03 00:20:23] |
This will be resolved in the next release coming out later today.
