Date/Time: Wed, 15 May 2024 09:05:17 +0000
Warning: This Custom DLL study may cause Sierra Chart to be unstable ...
View Count: 902
[2015-01-30 02:29:10] |
User726098 - Posts: 23 |
Hello, I just upgraded to the Pre-release 1226 for the OEC update per the notification. When I start my charts I get the following message that just scrolls on the Message Log and freezes sierra charts. Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:42 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:42 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:42 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:42 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:42 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:42 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:42 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2015-01-29 20:23:43 * Warning: The Custom DLL study "SierraChartStudies.scsf_CountDownTimer" has just caused a CPU exception. | 2015-01-29 20:23:43 * |
[2015-01-30 03:08:50] |
What I have noticed is, this appears once I'm connected to the service. When I begin to scroll back on any of my charts timeframe, the log will pop up with the above message and continue to log, it basically freezing the program. I have to exit and restart. I have also removed the countdown timer and re-applied it on the charts but same issue comes up.
Date Time Of Last Edit: 2015-01-30 03:09:27
[2015-01-30 03:20:10] |
We are fixing this problem now. We are going to be releasing Version 1227 in about 20 minutes.
[2015-01-30 04:43:17] |
Thanks. Just downloaded 1227 issue seems to be resolved.
