Date/Time: Wed, 02 Jul 2025 05:23:04 +0000
[User Discussion] - Automatically Plot Lines For High/Low of First Bar of Session Only
View Count: 2415
[2015-01-29 15:34:35]
cmet - Posts: 708
I'm looking to automatically plot extended horizontal lines of both the high and low of the first bar of the session only.
Is this possible? If so, what is the best approach to use? This needs to be based on the bar and not on time.
Looking for something simple like this:
http://s4.postimg.org/vo0pj1kpp/ohilo.jpg
Thanks in advance for any help.
Date Time Of Last Edit: 2015-01-29 15:34:52
[2015-01-29 16:00:47]
tickHunter - Posts: 14
I do this on a volume based chart, here is the code:
  This is a C++ source code file. This file contains example Advanced Custom
  Study functions. It also contains functions for some built-in studies
  in Sierra Chart.
#include "sierrachart.h"
SCDLLName("OS Marker")
SCSFExport scsf_OSMarker(SCStudyInterfaceRef sc)
  SCSubgraphRef OSHigh = sc.Subgraph[0];
  SCSubgraphRef OSLow = sc.Subgraph[1];
  SCSubgraphRef OSRange = sc.Subgraph[2];
  // Set configuration variables
  if (sc.SetDefaults)
    sc.GraphName = "OS Marker";
    sc.StudyDescription = "Marks the Opening Swing High and Low";
    sc.Input[1].Name = "Day Session Start";
    sc.Input[1].SetTime(HMS_TIME(8,30,0));
    sc.Input[2].Name = "Day Session End";
    sc.Input[2].SetTime(HMS_TIME(15,14,59));
    // Set the region to draw the graph in. Region zero is the main
    // price graph region.
    sc.GraphRegion = 0;
    // Set the name of the first subgraph
    OSHigh.Name = "Opening Swing High";
    OSLow.Name = "Opening Swing Low";
    sc.AutoLoop = 1;
    // During development set this flag to 1, so the DLL can be modified. When development is completed, set it to 0 to improve performance.
    sc.FreeDLL = 0;
    // Must return before doing any data processing if sc.SetDefaults is set
    return;
// Bar index of beginning of trading day for bar at current index. This depends upon auto looping being true.
int &dateToday = sc.PersistVars->i1;
SCDateTime BarDateTime = sc.BaseDateTimeIn[sc.Index];
dateToday = BarDateTime.GetDate();
SCDateTime StartTimeToday;
SCDateTime EndTimeToday;
float OSHighNum = sc.PersistVars->f1;
float OSLowNum = sc.PersistVars->f2;
StartTimeToday.SetDateTime(dateToday, sc.Input[1].GetTime());
EndTimeToday.SetDateTime(dateToday, sc.Input[2].GetTime());
int StartOfDayIndex = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, StartTimeToday);
int EndOfDayIndex = sc.GetContainingIndexForSCDateTime(sc.ChartNumber, EndTimeToday);
if(sc.Index == StartOfDayIndex) {
  OSHighNum = sc.BaseData[SC_HIGH][StartOfDayIndex];
  OSLowNum = sc.BaseData[SC_LOW][StartOfDayIndex];
  OSHigh[sc.Index] = OSHighNum;
OSLow[sc.Index] = OSLowNum;
  OSHigh.ExtendedArrayElementsToGraph = 10;
  OSLow.ExtendedArrayElementsToGraph = 10;
  else {
    OSHigh[sc.Index] = OSHigh[sc.Index - 1];
    OSLow[sc.Index] = OSLow[sc.Index - 1];
[2015-01-29 16:11:19]
cmet - Posts: 708
Perfect. Thanks a lot for this.
[2015-01-29 17:49:17]
Try using the High/Low for Time Period - Extended study and set the Start and End time to cover 1 minute.
[2015-01-29 17:51:56]
cmet - Posts: 708
Thanks but accurate opening swing is based on price, not time. Floor guy's I know who trade CL may use 1 minute but it's simply not useful in markets like ES (imo).
[2015-01-29 21:17:45]
When the time period is set to a short time like 1 minute, unless the chart bars are less than 1 minute, it will always map to the first bar only containing the specified Start Time.
Date Time Of Last Edit: 2015-01-29 22:47:07
[2015-01-29 21:47:40]
ejtrader - Posts: 688
pst - Pulled up this code from some other studies I have built and modified to meet this request.
There are no inputs to this study. If you set your session time correctly - it would pick the very first bar of the session and calculates the high/low for that chart ( chart can be of any type - not necessarily time based chart as long as session times are defined properly for the chart).
If you need any small customizations on this - can help you with that.
http://www.sierrachart.com/image.php?l=1422568017773.png
SCDLLName("HighLowBar")
SCSFExport scsf_HighLowBar(SCStudyInterfaceRef sc)
SCSubgraphRef hValue = sc.Subgraph[0];
SCSubgraphRef lValue = sc.Subgraph[1];
if (sc.SetDefaults) {
sc.GraphName = "HighLowBar";
sc.StudyDescription = "HighLowBar - Calculate High/Low for a Single Bar";
sc.GraphDrawType = GDT_CUSTOM;
sc.GraphRegion = 0;
sc.FreeDLL = 0;
sc.AutoLoop = 1;
hValue.Name = "HighValue";
hValue.DrawStyle = DRAWSTYLE_RIGHTHASH;
hValue.PrimaryColor = COLOR_DARKGRAY;
hValue.DrawZeros = false;
lValue.Name = "LowValue";
lValue.DrawStyle = DRAWSTYLE_RIGHTHASH;
lValue.PrimaryColor = COLOR_DARKGRAY;
lValue.DrawZeros = false;
return;
int &lastIndex = sc.GetPersistentInt(0);
if (sc.UpdateStartIndex == 0) {
lastIndex = -1;
int i = sc.Index;
if (lastIndex == sc.Index) {
return;
lastIndex = sc.Index;
hValue[i] = hValue[i - 1];
lValue[i] = lValue[i - 1];
if (sc.BaseDateTimeIn[i - 2].GetTime() < sc.SessionStartTime()
&& sc.BaseDateTimeIn[i - 1].GetTime() >= sc.SessionStartTime()) {
hValue[i] = sc.High[i - 1];
lValue[i] = sc.Low[i - 1];
return;
Date Time Of Last Edit: 2015-01-29 22:20:24
[2015-01-29 22:13:22]
cmet - Posts: 708
Thanks. Use non time based bars so it can take more than 1 minute for the swing.
The code from tickHunter works perfectly.
Appreciate the help.
Date Time Of Last Edit: 2015-01-29 22:14:39
