Date/Time: Wed, 15 May 2024 12:38:55 +0000
Tool coordinates when marking a chart
View Count: 1122
[2015-01-28 22:49:20] |
Willson - Posts: 176 |
Is there a way to show temporary lines or rays showing location of the cross-hair or pointer on the time and price axis in order to accurately position a marker (like an X or a circle). I would expect the rays to the coordinates to disappear when the marker is completed leaving only the marker. As it is for me now; when I use a marker tool, the crosshairs disappear and i can not position the marker unless I use a data display window which slows the procedure immensely. What am I missing? Regards |
[2015-01-29 18:12:21] |
You will want to enable the Chart Values tool option to keep it active when using other tools. Here is the documentation: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
