Date/Time: Wed, 15 May 2024 22:10:34 +0000
Relationsship of candle with to length
View Count: 802
[2015-01-28 18:33:52] |
tellerbe - Posts: 109 |
If I place my cursor over the price column and scroll down, the candles become taller but also wider. How can I unhook these from moving together. T.Ellerbee |
[2015-01-28 18:51:05] |
Open the Scale settings for the chart and uncheck Use Constant Relationship. Here are instructions: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
