Date/Time: Sat, 18 May 2024 18:26:30 +0000
countdown timer
View Count: 1069
[2015-01-28 14:43:40] |
julian pineda - Posts: 60 |
How can i configure a countdown timer alert? for example i use a volume per bar 40.000 contracts. how i do that the platform alert me when the 40.000 its almost over? thanks, |
[2015-01-28 19:10:32] |
We need to add the capability for the Countdown Timer study to set the remaining countdown value into the study Subgraph. This will be done in the next release. You can then write a simple alert formula on the study like: =SG1 < 100 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-29 16:34:49] |
and can you tell me how to configure the alert: a color bar based on i want me SC alert me visual and no aurally for example: return me the green bar when the condition is met (ask) and return me the red bar when the condition is met(bid) how i configure that? |
[2015-02-24 13:33:09] |
User63439 - Posts: 83 |
We need to add the capability for the Countdown Timer study to set the remaining countdown value into the study Subgraph. This will be done in the next release. any news on that? |
[2015-02-24 18:32:08] |
This has been done for the Countdown Timer study. Although whether a value is outputted to the Subgraph of the study depends get upon the output of the Countdown Timer study. So it does not work in all cases.
[2015-02-24 22:01:34] |
must be my lacking english, i understand nothing. is it possible to get an alert 10 seconds before the 5 min bar closes or not? if yes how thank you |
[2015-02-25 07:56:28] |
Yes, we can support this but we want to make another change to make this as easy as possible.
[2015-02-25 09:30:36] |
ok thanks, looking forward to it
[2015-02-26 04:08:39] |
Support for this will be out in the next release. You will need to set the Display Value Only input to Yes. In the case of when chart bars are based upon a fixed amount of time, the remaining time is outputted to the Subgraph array in seconds. The formula you will use is: SG1 <= 10 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-26 11:17:45] |
great, thank you guys
