Date/Time: Thu, 16 May 2024 14:59:12 +0000
IQ feed
View Count: 764
[2015-01-28 09:32:19] |
stephensmart - Posts: 51 |
Hi, i am using IQ for data in sierra, i also want to use the fxcm feed for forex data, do i need to run 2 instances of sierra to achieve this?
[2015-01-28 10:09:16] |
Yes, install another copy of Sierra Chart following the instructions here: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
