Date/Time: Thu, 16 May 2024 03:41:40 +0000
Can't find the replay window!
View Count: 1267
[2015-01-28 03:34:39] |
FFTrader - Posts: 180 |
Hi support, I recently moved around my graphics cards and screens - so all instances of Sierra Charts are repositioned. As such, some instances's replay sub-window is no where to be found on my screen real estate. Although I managed to get the replay working - by hitting "Tab" 5 times and then hitting the space bar and get it to run - to prove that it is working, I still cannot move the replay sub-window back onto my screen anywhere on my real estate. Solution is? Date Time Of Last Edit: 2015-01-28 03:36:28
[2015-01-28 03:35:46] |
Select Window >> Reset Windows.
[2015-01-28 03:36:45] |
Oh ok.
