Date/Time: Thu, 16 May 2024 11:01:44 +0000
How to hide Subgraphs under a Study (indicator)
View Count: 1563
[2015-01-28 02:17:58] |
BillyBear888 - Posts: 3 |
Please help hide information on more than one Subgraph under a Study/indicator. Explanation of Chart Studies on Sierra Chart: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#PasswordProtectingStudies not sufficient information to hide all the subgraphs under a Study/indicator. With password protection, “names and inputs” cannot be seen but most “Studies” (indicators) are easily identifiable. For example, under Subgraphs: For any Studies with more than one “Subgraphs,” password protection leaves very easily identifiable traces For example, Study “RSI” shows the fourth line item RSI Avg (SG4) which indicates that it is a RSI study. Study “Pivot Point” with the exception of the first line item, shows all the Rs, Ss, PPs which easily indicates it as a Pivot Point study. |
SierraChart2.jpg / V - Attached On 2015-01-28 02:15:59 UTC - Size: 305.18 KB - 389 views |
[2015-01-28 18:48:59] |
Follow step 4 here: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#PasswordProtectingStudies Make sure you set a Short Name for each Subgraph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
