Date/Time: Wed, 15 May 2024 11:28:01 +0000
CW drop down window no longer alphabetized
View Count: 1097
[2015-01-27 16:48:44] |
MMX - Posts: 119 |
I upgraded from v1212 to v1224 and found that the drop down window listing all the charts in the chartbook is no longer alphabetized. For years it's always been alphabetized. I have 35 to 40 charts in a chartbook and some of them are hidden, I activate the hidden ones through the CW button. Now it's a mess, I have to search through a list of 35 to 40 different contracts every time I want to bring up a hidden window, and that's aggravating. Will you please return the CW drop down window to its original alphabetized state. Thank you.
[2015-01-27 16:57:29] |
Uncheck: Global Settings >> General Settings >> General 2 >> Sort CW Menu by Chart Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
