Date/Time: Wed, 15 May 2024 12:40:39 +0000
Horizontal Line at time study
View Count: 860
[2015-01-27 01:50:50] |
User17052 - Posts: 30 |
Hi, How do I plot horizontal line at time say 6:35 PST using study "Horizontal Line at time study" for weekdays only and ignoring weekends? Thanks. |
[2015-01-27 02:42:45] |
You have to remove the weekends from the chart by unchecking Chart >> Chart Settings >> Load Weekend Data.
[2015-01-27 03:05:37] |
Thanks. Actually I need the data on chart. Only the horizontal line I need to draw should ignore weekend data. What do you suggest? Thanks. |
[2015-01-28 04:34:17] |
Our only suggestion is to modify the existing study to meet your requirements. Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
