Date/Time: Sun, 19 May 2024 01:11:26 +0000
Floor traders pivot
View Count: 2182
[2015-01-27 01:36:04] |
User17052 - Posts: 30 |
Hi, How do I add study that plots "Floor traders pivot" on ES futures? Study provided with Sierra plots different values than "Floor traders pivot". Thanks. |
[2015-01-27 17:04:12] |
Most likely Sierra Chart does have the formula you need. Refer to the Formula Types available with the Pivot Points-Daily study: http://www.sierrachart.com/index.php?page=doc/doc_PivotPoints.html#PPFormulas Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-02-04 03:15:16] |
Thanks.
