Date/Time: Sat, 18 May 2024 03:52:06 +0000
Time Scale
View Count: 1023
[2015-01-26 22:38:29] |
Hill - Posts: 1 |
I want to compress the time scale to allow more data to be visible on a 1 tick chart. I can compress the horizontal scale quite a bit by using the constant range feature but do not see a way to do the same with the time scale. I can get about 15 minutes of data on a tick chart but would like to be able to adjust to get more time. Any suggestions? Thanks |
[2015-01-26 23:11:54] |
Other than reducing the bar spacing as explained here, there is nothing else that can be done: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChangingBarSpacing You will need to increase the timeframe of the chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
