Date/Time: Mon, 20 May 2024 18:57:35 +0000
Just an FYI re: Freeze Issue
View Count: 846
[2015-01-23 16:21:39] |
OneMoreTick - Posts: 79 |
Just an FYI that you might want to add another item to this list: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html One of my charts was freezing and I narrowed the issue to a drawing that was being to copied to that chart via "Copy Chart Drawings From Chart #s". I didn't see that on the list, so that might help out others with the same issue. It's kind of indirectly referenced by 30.9 but that's not the same thing. Date Time Of Last Edit: 2015-01-23 16:23:07
[2015-01-23 16:54:07] |
What is the drawing type? And what version of Sierra Chart are you running? It may be something that we need to correct or it may have been corrected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-23 16:57:12] |
v 1220. They're horizontal rays. I was cutting them when price crossed and keeping them on the chart for later reference. When I removed the ones that I cut (but leaving the extended ones), the issue went away.
[2015-01-23 17:22:08] |
We will look into this. Those definitely should not cause high CPU usage.
