Date/Time: Mon, 20 May 2024 15:42:30 +0000
Have to turn-off confirmations every log-in
View Count: 816
[2015-01-23 15:32:07] |
User757207 - Posts: 45 |
Every log-in now since updating to the latest SC, it says "1217", I have to manually re-type my attached orders in the attached Trade Window (default is stop 10T and target 10T). Moreover, I have to go to "M" and turn off all confirmations, despite turning them off in the session before and hitting SAVE ALL when closing out. How do I work around this problem? |
[2015-01-23 23:25:51] |
Make sure you are opening the Chartbook you are previously using and not opening new charts which will have default settings. Here is the information about Chartbooks: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html When looking into this problem, it seemed as though we could duplicate the issue but upon further testing we could not and we see no reason why this would occur. However, you need to consider that as you change the Trade Window configuration, the saved settings for the configuration will be used. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-23 23:26:26
