Date/Time: Sun, 28 Apr 2024 09:39:52 +0000
Bar End Date?
View Count: 1886
[2013-03-25 21:21:43] |
gratalis - Posts: 6 |
Is there a way to use the 'write bar data to file' in a way that includes the end date and time stamp of each bar in addition to the included start date and time stamp? I see a 'bar end time' study but it appears to include a time stamp only, no date. Thanks |
[2013-03-25 21:41:11] |
No, this is not supported.
[2013-03-25 21:44:43] |
I'm sure it is a low priority but I would appreciate it if you would consider developing this capability in the future preferably as a feature of the 'write bar data to file' study or as an extension to the existing 'bar end time' study. Thank You |
