Date/Time: Sat, 18 May 2024 04:37:23 +0000
Spreadsheet Column Headings
View Count: 740
[2015-01-22 22:17:23] |
User28366 - Posts: 14 |
How do I move the location/order of the columns and then sort on a specific heading?
[2015-01-22 22:30:53] |
This is not supported. However, are you referring to a Spreadsheet when using the Spreadsheet study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-26 05:23:49] |
User16301 - Posts: 4 |
Yes |
