Date/Time: Tue, 21 May 2024 03:44:04 +0000
Action before study recalculation
View Count: 849
[2015-01-22 19:41:56] |
User53601 - Posts: 105 |
Similarily like an sc.LastCallToFunction is there any posiibility to call a piece of code before the study is recalculated? I want to delete drawings before recalculation. It works fine with sc.LastCallToFunction, when I need to delete drawings before removing the study. Would need similar functionality for the case of recalculation. |
[2015-01-22 21:26:03] |
You can determine this by looking at sc.UpdateStartIndex. It will be 0 on a recalculation.
[2015-01-22 22:41:40] |
this is what you mean by using sc.UpdateStartIndex? if ( sc.UpdateStartIndex == 0 ) { peace of code executed BEFORE recalculation ? } |
[2015-01-22 23:43:06] |
Yes. Exactly. This is what we use all the time when necessary to perform certain actions on a recalculation.
