Date/Time: Tue, 21 May 2024 05:37:31 +0000
Can't select drawn VbP sometimes
View Count: 890
[2015-01-22 03:46:31] |
joshtrader - Posts: 442 |
The option is enabled -- why is it sometimes on charts I can select them, sometimes I cannot? Has anyone else noticed this? Edit: SC, please delete this thread if you like. The reason is that "Hide Chart Drawings" was selected and this prevents drawn VbP from being selected. When I show them again, I can select them as expected. Date Time Of Last Edit: 2015-01-22 03:47:30
[2015-01-22 03:47:30] |
We would need to get a Chartbook from you containing the one single chart that has the drawn volume profile that cannot be selected, so we can test it. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-22 03:48:30] |
Per first post edit, you can safely delete the thread, sorry for the mistake.
