Date/Time: Fri, 10 May 2024 05:14:56 +0000
Multiple Instalations of SC
View Count: 748
[2015-01-21 20:36:08] |
Trade Nice - Posts: 75 |
I would like to use multiple installations of SC to spread processing load. In past times I had understood there wasn't a limit, but when I just tried I got a message about using too many with three installations. With one account, how many installations of Sierra Charts can I use at the same time on a) one computer? b) multiple computers at same location? |
[2015-01-21 21:09:06] |
There is no limit on the number of running installations on the same computer unless you are running them in separate virtual machines on the same system. With multiple computers, you can use Sierra Chart on two systems at a time. Each system can contain multiple installations running at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-23 17:52:26] |
ADRTvent - Posts: 23 |
Is there a way to increase the number of allowed systems per account? Can I use 10 Systems for one account? or do I have to open 5 separate accounts, please advise
[2017-06-23 18:14:45] |
You can increase the systems here but not all the way up to 10: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
