Date/Time: Fri, 17 May 2024 18:29:33 +0000
SC error
View Count: 810
[2015-01-21 19:07:42] |
George - Posts: 60 |
I had some computer trouble, hopefully fixed it, but when starting SC I received a "Configuration File Checksum Error" message. I closed the message then SC started, but alot of my charts and startup chartbooks are full of changes, ie colors different and global general settings reverted to default settings. Any idea how fix this? Does anyone know what caused this? I solved one problem, the startup chartbooks, it defaulted to using the "Data" folder and I was using a different folder. I cannot logon on to Rithmic, this error message keeps repeating in the message log: Error running C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified.|2015-01-21 11:45:04. It keeps trying a different port, but the same error keeps occurring. Need help. Date Time Of Last Edit: 2015-01-21 20:00:13
[2015-01-21 21:41:15] |
Install Sierra Chart again into the same folder. To do this select Help >> Download Prerelease (New Spreadsheets). You can restore a backup configuration file by following these instructions here: https://www.sierrachart.com/index.php?page=doc/helpdetails39.html#RestoringBackupGlobalConfigurationFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-21 21:41:54
