Date/Time: Mon, 20 May 2024 16:36:29 +0000
which tool to do that
View Count: 870
[2015-01-21 18:52:10] |
chris12 - Posts: 51 |
hi SC Which tool is this ?? to get tick, vol, and delta with the line ?? thx |
Capture d’écran 2015-01-21 à 17.50.33.png / V - Attached On 2015-01-21 18:49:10 UTC - Size: 87.32 KB - 417 views |
[2015-01-22 00:28:56] |
jivetrader - Posts: 395 |
ZigZag study>>Display ZigZag Volume / Display Length of ZigZag Line
[2015-01-23 09:50:29] |
Look at the Zig Zag study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s133 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
