Date/Time: Fri, 17 May 2024 18:29:17 +0000
Rithmic backfill question
View Count: 902
[2015-01-21 17:36:43] |
joshtrader - Posts: 442 |
On the rithmic page it says: For service package 5 users, tick by tick historical Intraday data is provided. To access the detailed historical Intraday data, Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds needs to be enabled.
However, I do not have to subscribe to the SC data feed in order to get the up-to-the-moment backfill, correct? And with this setup, real-time data will come from rithmic, correct? |
[2015-01-21 18:27:17] |
Yes, this is correct. And the data will come from Rithmic. However, for the most recent 10 to 15 minutes of Intraday data downloaded, you will not get bid volume or ask volume from Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-21 18:27:36
[2015-01-22 00:06:29] |
2garin - Posts: 184 |
Good afternoon. If historical data is loaded fully with servers Rithmic (Sierra Chart Data Fed) is not used, null values in the bid / ask data disappear? The question is not due to the correct (zero) values of the bid / ask two / three candles while loading historical tick data. Date Time Of Last Edit: 2015-01-22 00:12:42
