Date/Time: Mon, 20 May 2024 12:43:41 +0000
Sierracharts web page does not work in Colombia
View Count: 843
[2015-01-20 00:55:27] |
CMG - Posts: 179 |
Hello, I am trying to access www.sierrachart.com from Bogota, Colombia and I am getting a message that it requires authetication, do you know how to bypass this? I enter the username and password that it ask for but nothing happens. TKS |
SierraChart.png / V - Attached On 2015-01-20 00:40:34 UTC - Size: 22.42 KB - 336 views Attachment Deleted. |
[2015-01-20 01:32:33] |
We do not see how it is the Sierra Chart website causing the display of that authentication prompt. It must be from proxy server that the ISP is using.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-20 02:16:40
