Date/Time: Mon, 20 May 2024 12:43:34 +0000
Tool: Ellipse
View Count: 1368
[2015-01-19 18:49:37] |
QnReally - Posts: 181 |
I tried a few things but I can't figure out if I am really doing something wrong. I am trying to draw an ellipse highlight but it draws a rectangle highlight. I only have one instance of Sierra Chart installed on my computer. I recently switched to 2010 VC++ from the 2008 version. I am running v1224 of SC currently. SCSFExport scsf_TestEllipse(SCStudyGraphRef sc) { if (sc.SetDefaults) { sc.GraphName="Test Ellipse"; sc.StudyDescription="Test Ellipse Drawing"; sc.AutoLoop = 0; sc.FreeDLL = 1; return; } if (sc.HideStudy) return; s_UseTool Tool; Tool.Clear(); Tool.ChartNumber = sc.ChartNumber; Tool.Tool = DRAWING_ELLIPSEHIGHLIGHT; Tool.Region = sc.GraphRegion; Tool.AddMethod = UTAM_ADD_OR_ADJUST; Tool.TransparencyLevel = 50; Tool.LineWidth = 0; Tool.UseRelativeVerticalValues = 1; Tool.BeginDateTime = 40; Tool.BeginValue = 40; Tool.EndDateTime = 70; Tool.EndValue = 60; Tool.SecondaryColor = RGB(128,128,128); Tool.LineNumber = 102; sc.UseTool(Tool); } http://www.sierrachart.com/image.php?l=1421693306518.png Do you have any pointers on what could be wrong? Thanks. |
[2015-01-19 19:44:49] |
Al SC Developer - Posts: 434 |
You should be setting the DrawingType instead of Tool: DrawingType = DRAWING_ELLIPSEHIGHLIGHT; |
[2015-01-19 20:45:25] |
Tool.Tool is old and only there for back compatibility. We do need to remove it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
