Date/Time: Tue, 21 May 2024 00:40:47 +0000
Hidden numbers bar and trading chart DOM color adjustments
View Count: 1143
[2015-01-19 18:04:51] |
User947911 - Posts: 12 |
Hello, my last numbers bar is partially hidden behind the price range. Where can I change the settings in order to show the last bar clearly? I am able to send a screenshot if necessary. My second questions is, where can I adjust colors of the trading chart DOM? Looking forward to your respond. Thank you |
[2015-01-19 18:09:26] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image To change colors of the Chart DOM, refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizingGraphics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-21 13:38:23] |
The screenshot can be found below, I had some difficulties uploading it via your tutorial. http://ge.tt/8xyZD092/v/0?c |
[2015-01-21 22:13:22] |
You need to increase the right side fill space: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart It looks like this is the pullback column which is being hidden partially. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
