Date/Time: Sat, 18 May 2024 06:48:17 +0000
Numbers Bars Question (Using Diagonal)
View Count: 1220
[2015-01-16 15:33:11] |
infpz - Posts: 826 |
For Column 1 Text/Background Coloring Options - if the Column 1 threshold is met and the color of the text changes accordingly, is there a way to also change the color of the weaker (non dominnant) text or background?
[2015-01-26 19:25:38] |
User60287 - Posts: 19 |
I would like to know this answer as well. If the answer is NO then could we have control over which diagonal is calculating? (lower left to upper right separate from lower right to upper left)? Having both diagonals always calculate forces me to search for the matching ratio. I can do the math in my head because that is what I did before numbers bars or any of their relatives, but obviously that is not my intent. any help would be greatly appreciated from support or other users .
[2015-01-29 05:23:22] |
We will get back to you on this.
[2015-09-23 15:57:56] |
Hello Support and Users: I was hoping to get any helpful feedback on the diagonal control for the Numbers Bars. If this is not going to happen, may I be referred to any link that can help me make use of the dual diagonal comparison current build? Or a work around setting? Thanks |
[2015-09-23 18:37:10] |
We apologize for not getting back to you on this. It might have been a case where the programmer who worked on this, who was assigned this did not respond. If the answer is NO then could we have control over which diagonal is calculating? (lower left to upper right separate from lower right to upper left)?
The comparison is always from the lower left to the upper right. This cannot be changed and there are no plans to add the other direction.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-23 18:37:41
[2015-09-24 08:35:52] |
User31732 - Posts: 32 |
Hello, User60287. You can do this if you set up first threshold less than 100 and play with colors. Hope this help. Date Time Of Last Edit: 2015-09-24 08:41:24
