Date/Time: Mon, 20 May 2024 21:28:10 +0000
CME CRUDE OIL EXCHANGE TRADED SPREADS
View Count: 1154
[2015-01-16 13:04:56] |
Meritus - Posts: 164 |
Hi, I'm currently using SR Real Time and Historic service for my data but there is no Nymex exchange traded CL calendar spreads in the Find Symbol / Available Symbol box. I have created high accuracy spread charts for some of the back months but I am getting ticks which do not correspond to prices that are actually tradeable hence the need to look at the actual exchange traded spread products Please advise on what my options would be in order to receive the exchange traded calendar spreads. Would I need to change data feeds and if so, to which one? Many thanks in advance Date Time Of Last Edit: 2015-01-16 16:08:47
[2015-01-20 02:31:58] |
For exchange traded spreads you can use IQ Feed or CTS T4: DTN IQ Feed Data Service https://www.sierrachart.com/index.php?page=doc/CTS_T4.php Unfortunately, we have not yet fully implemented the capability for spreads. But we will have a look into this in the next few weeks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-20 12:31:01] |
Thank you for this answer. Just so I am clear, when you say you will look into this over the next few weeks does this suggest it may be worth me holding out till the beginning of March to see if you guys have had a chance to implement the capability for spreads?
[2015-01-20 19:49:51] |
You may want to wait and we actually discussed this today, and have most of the details worked out for spreads, but one item is hard to solve and we are not quite certain how quickly we can do it.
