Date/Time: Wed, 15 May 2024 20:07:21 +0000
Hot to set TCP or UDP connection with TransAct
View Count: 902
[2015-01-14 09:12:34] |
Carl71 - Posts: 125 |
I am not able to find this option via Global Settings > Data/Trade Service Settings Currently the charts are updated by trades and I don't want this |
[2015-01-14 09:44:42] |
This is controlled through the TransAct bridge program that you can access through the system tray on your Windows taskbar.
[2015-01-14 12:59:50] |
Thanks I forgot it... |
