Date/Time: Thu, 16 May 2024 06:11:57 +0000
Unable to connect to OEC
View Count: 768
[2015-01-11 23:35:42] |
User49270 - Posts: 48 |
Hi, I keep getting a waiting to reconnect message. I checked with OEC everything is good on there end with the data feed. I am also able to connect to OEC Trader with no problem. Thanks
[2015-01-11 23:49:05] |
We are contacting OEC about this data. We see the same problem.
[2015-01-12 01:48:49] |
Ok, OEC said they were going to reset their servers, they did and I am able to connect now. Thanks
