Date/Time: Tue, 12 May 2026 00:13:32 +0000
[User Discussion] - Testing IQ Feed against IB
View Count: 2357
| [2013-05-21 21:12:37] |
| Tonkadad - Posts: 235 |
I just signed up for the IQ Feed trial and wondered how can I keep my existing charts created by IB to compare them against IQ Feed? A second installation of SC in a new folder? I want to compare them real time using tick data based charts. thanks |
| [2013-05-21 21:22:52] |
Yes, we recommend installing another copy of Sierra Chart. Refer to Multiple Services in the documentation.
| [2013-05-21 21:59:23] |
What files can I transfer over that will setup my tool bars, preferences etc... By the way, thank you fro the quick response. |
| [2013-05-21 22:11:42] |
See: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-05-22 19:05:58] |
Thought I would post a chart from each data feed IQ Feed and IB using a 454 vol chart for both and see if anyone can tell which is which.
