Date/Time: Tue, 30 Apr 2024 06:10:12 +0000
Sierra Charts for futures and stocks at the same time on same pl
View Count: 1476
[2013-05-21 18:38:47] |
You will need to install a 2nd copy of Sierra Chart. Follow the instructions here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html All supported services can be found here: http://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
