Date/Time: Sat, 12 Jul 2025 00:50:01 +0000
IQFeed
View Count: 1834
[2013-05-21 18:13:34] |
User39772 - Posts: 311 |
IQ feed uses the symbol EURUSD.FXCM. When I run a spreadsheet system with this symbol and fire orders to TWS, TWS does not react. I guess the reason is the different syntax for forex symbols. Ho can I handle this ? I tried to change the symbol name in J40, but this did not work ! |
[2013-05-21 18:40:19] |
You need to set the Alternate Real-time Update Symbol: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#AlternateRealTimeUpdateSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
