Date/Time: Sun, 05 May 2024 11:58:30 +0000
[User Discussion] - Data Feed
View Count: 1453
[2013-05-21 18:03:42] |
User39772 - Posts: 311 |
Hello, is it possible to share the data feed between several SC instances that DO NOT run on the same machine, w.g. via the network or would it be possible to implement such an feature (the processor of one machine might be to weak in some cases) ? |
[2013-05-23 05:24:39] |
No, this will not work.
