Date/Time: Mon, 13 May 2024 20:25:54 +0000
No data on ES# symbol
View Count: 1027
[2014-12-29 19:14:21] |
User67344 - Posts: 7 |
Dear All it may concern,. Since the 29/12/14 I do not accept any info on the ES$ (intraday,daily,weekly,monthly)symbol information - The information is available for ESH5. I have tried the usual option to delete and refresh intraday data or delete & refresh intraday datat for all charts but can't see it sync automatically. working with Ineractive broker. it worked until last week please let me know if you need me to provide my message log. Best regards, Arie |
[2014-12-29 19:41:07] |
In the case of Interactive Brokers ES# and ES$ are not valid symbols. So you should not get any data or the data you would get, would not match the intended symbol. If you want a continuous futures contract chart, follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-29 19:41:24
[2014-12-29 20:28:30] |
the symbol is ES-201503-GLOBEX.scid and again it worked before please assist |
[2014-12-29 20:32:53] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-29 20:47:15] |
[2014-12-29 20:47:29] |
Software version: 1220 | 2014-12-29 15:38:36 Uses New Spreadsheets | 2014-12-29 15:38:36 Usage end date: 2015-01-26 | 2014-12-29 15:38:36 Enabled for: Advanced Features. | 2014-12-29 15:38:36 Enabled for: Advanced Features 2. | 2014-12-29 15:38:36 Enabled for: Sierra Chart Historical Data Service. | 2014-12-29 15:38:36 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-29 15:38:36 Active service: Interactive Brokers | 2014-12-29 15:38:36 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-29 15:38:36 2014-12-29 22:38:36 Local computer clock time | 2014-12-29 15:38:36 2014-12-29 20:38:36 GMT time | 2014-12-29 15:38:36 2014-12-29 15:38:36 Time zone adjusted time | 2014-12-29 15:38:36 Time difference to server time: 40 seconds. | 2014-12-29 15:38:36 WARNING: Your computer's clock is off by 40 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2014-12-29 15:38:36 Program path: C:\SierraChart\ | 2014-12-29 15:38:36 Data Files path: C:\SierraChart\Data\ | 2014-12-29 15:38:36 OS Version Number: 5.1 | 2014-12-29 15:38:36 Locale Information: C | 2014-12-29 15:38:36 Checking for new symbol settings for ib | 2014-12-29 15:38:37 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2014-12-29 15:38:37 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2014-12-29 15:38:37 Symbol settings are up-to-date for ib | 2014-12-29 15:38:37 Files to Open on Start up | Opening file: es1.cht | 2014-12-29 15:38:40 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2014-12-29 15:38:42 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2014-12-29 15:38:42 Intraday data recording state for symbol ES-201409-GLOBEX is set to download pending. | 2014-12-29 15:38:43 HD Request # 2 | Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: cme | 2014-12-29 15:38:43 HD Request # 2 | Download start Date-Time: 2014-09-19 09:29:59.0 | 2014-12-29 15:38:43 HD Request # 2 | Using server: scdf2.sierracharts.com port 10149 | 2014-12-29 15:38:43 HD Request # 3 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: ib | 2014-12-29 15:38:43 HD Request # 3 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2014-12-29 15:38:43 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-12-29 15:38:44 Socket (2) | Connected. | 2014-12-29 15:38:44 HD Request # 2 | Sending historical data logon request message. | 2014-12-29 15:38:44 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:38:44 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:29:59. Record interval: 0. Symbol: ESU4 | 2014-12-29 15:38:44 HD Request # 2 | Decompressing data. | 2014-12-29 15:38:44 HD Request # 2 | Receiving Intraday data for ES-201409-GLOBEX starting at 2014-09-19 09:29:59 | 2014-12-29 15:38:44 Socket (2) | Shutdown and closed. | 2014-12-29 15:38:44 The network socket for historical data has been closed. | 2014-12-29 15:38:44 HD Request # 2 | Historical data for ES-201409-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-12-29 15:38:44 HD Request # 2 | Received 1 record from 2014-09-19 09:29:59 to 2014-09-19 09:29:59 (0.0 seconds) and wrote 0 records for ES-201409-GLOBEX | 2014-12-29 15:38:44 HD Request # 2 | Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 0s. Unique request ID: 1 | 2014-12-29 15:38:44 Removed historical data download ID 1 | 2014-12-29 15:38:44 HD Request # 3 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2014-12-29 15:38:44 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2014-12-29 15:38:44 HD Request # 3 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2014-12-29 15:38:44 HD Request # 3 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 2 | 2014-12-29 15:38:44 Removed historical data download ID 2 | 2014-12-29 15:38:44 Socket (3) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:38:45 Socket (3) | Shutdown and closed. | 2014-12-29 15:38:45 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:38:45 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:38:45 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:38:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:38:45 Disconnected from IB. | 2014-12-29 15:38:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:38:45 Starting TWS auto-login thread. | 2014-12-29 15:38:48 TWS auto-login thread ending. | 2014-12-29 15:38:48 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:38:50 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:38:51 Socket (4) | Shutdown and closed. | 2014-12-29 15:38:51 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:38:51 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:38:51 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:38:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:38:51 Disconnected from IB. | 2014-12-29 15:38:52 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:38:52 Starting TWS auto-login thread. | 2014-12-29 15:38:52 TWS auto-login thread ending. | 2014-12-29 15:38:52 Starting TWS auto-login thread. | 2014-12-29 15:38:56 TWS auto-login thread ending. | 2014-12-29 15:38:56 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:38:57 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:38:58 Socket (5) | Shutdown and closed. | 2014-12-29 15:38:58 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:38:58 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:38:58 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:38:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:38:58 Disconnected from IB. | 2014-12-29 15:38:58 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:38:58 Starting TWS auto-login thread. | 2014-12-29 15:39:01 TWS auto-login thread ending. | 2014-12-29 15:39:01 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:04 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:05 Socket (6) | Shutdown and closed. | 2014-12-29 15:39:05 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:05 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:05 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:05 Starting TWS auto-login thread. | 2014-12-29 15:39:05 TWS auto-login thread ending. | 2014-12-29 15:39:05 Disconnected from IB. | 2014-12-29 15:39:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:05 Starting TWS auto-login thread. | 2014-12-29 15:39:10 TWS auto-login thread ending. | 2014-12-29 15:39:10 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:10 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:12 Socket (7) | Shutdown and closed. | 2014-12-29 15:39:12 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:12 Disconnected from IB. | 2014-12-29 15:39:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:13 Starting TWS auto-login thread. | 2014-12-29 15:39:14 TWS auto-login thread ending. | 2014-12-29 15:39:14 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:18 Starting TWS auto-login thread. | 2014-12-29 15:39:18 TWS auto-login thread ending. | 2014-12-29 15:39:18 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:19 Socket (8) | Shutdown and closed. | 2014-12-29 15:39:19 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:19 Disconnected from IB. | 2014-12-29 15:39:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:20 Starting TWS auto-login thread. | 2014-12-29 15:39:22 TWS auto-login thread ending. | 2014-12-29 15:39:22 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:25 Starting TWS auto-login thread. | 2014-12-29 15:39:26 TWS auto-login thread ending. | 2014-12-29 15:39:26 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:27 Socket (9) | Shutdown and closed. | 2014-12-29 15:39:27 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:27 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:27 Disconnected from IB. | 2014-12-29 15:39:27 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:27 Starting TWS auto-login thread. | 2014-12-29 15:39:30 TWS auto-login thread ending. | 2014-12-29 15:39:30 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:32 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:33 Socket (10) | Shutdown and closed. | 2014-12-29 15:39:33 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:33 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:33 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:33 Disconnected from IB. | 2014-12-29 15:39:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:33 Starting TWS auto-login thread. | 2014-12-29 15:39:34 TWS auto-login thread ending. | 2014-12-29 15:39:34 Starting TWS auto-login thread. | 2014-12-29 15:39:38 TWS auto-login thread ending. | 2014-12-29 15:39:38 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:38 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:40 Socket (11) | Shutdown and closed. | 2014-12-29 15:39:40 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:40 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:40 Disconnected from IB. | 2014-12-29 15:39:40 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:40 Starting TWS auto-login thread. | 2014-12-29 15:39:42 TWS auto-login thread ending. | 2014-12-29 15:39:42 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:45 Starting TWS auto-login thread. | 2014-12-29 15:39:46 TWS auto-login thread ending. | 2014-12-29 15:39:46 Socket (12) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:46 Socket (12) | Shutdown and closed. | 2014-12-29 15:39:46 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:46 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:46 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:46 Disconnected from IB. | 2014-12-29 15:39:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:46 Starting TWS auto-login thread. | 2014-12-29 15:39:50 TWS auto-login thread ending. | 2014-12-29 15:39:50 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:51 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:52 Socket (13) | Shutdown and closed. | 2014-12-29 15:39:52 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:52 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:52 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:52 Disconnected from IB. | 2014-12-29 15:39:52 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:52 Starting TWS auto-login thread. | 2014-12-29 15:39:54 TWS auto-login thread ending. | 2014-12-29 15:39:56 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:39:58 Starting TWS auto-login thread. | 2014-12-29 15:39:58 TWS auto-login thread ending. | 2014-12-29 15:39:58 Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:39:59 Socket (14) | Shutdown and closed. | 2014-12-29 15:39:59 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:39:59 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:39:59 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:39:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:39:59 Disconnected from IB. | 2014-12-29 15:39:59 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:39:59 Starting TWS auto-login thread. | 2014-12-29 15:40:02 TWS auto-login thread ending. | 2014-12-29 15:40:02 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:04 Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:05 Socket (15) | Shutdown and closed. | 2014-12-29 15:40:05 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:05 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:05 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:05 Disconnected from IB. | 2014-12-29 15:40:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:05 Starting TWS auto-login thread. | 2014-12-29 15:40:06 TWS auto-login thread ending. | 2014-12-29 15:40:06 Starting TWS auto-login thread. | 2014-12-29 15:40:10 TWS auto-login thread ending. | 2014-12-29 15:40:10 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:11 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:12 Socket (16) | Shutdown and closed. | 2014-12-29 15:40:12 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:12 Disconnected from IB. | 2014-12-29 15:40:12 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:12 Starting TWS auto-login thread. | 2014-12-29 15:40:14 TWS auto-login thread ending. | 2014-12-29 15:40:14 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:17 Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:18 Socket (17) | Shutdown and closed. | 2014-12-29 15:40:18 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:18 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:18 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:18 Starting TWS auto-login thread. | 2014-12-29 15:40:18 Disconnected from IB. | 2014-12-29 15:40:18 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:18 TWS auto-login thread ending. | 2014-12-29 15:40:18 Starting TWS auto-login thread. | 2014-12-29 15:40:22 TWS auto-login thread ending. | 2014-12-29 15:40:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:23 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:24 Socket (18) | Shutdown and closed. | 2014-12-29 15:40:24 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:24 Disconnected from IB. | 2014-12-29 15:40:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:25 Starting TWS auto-login thread. | 2014-12-29 15:40:26 TWS auto-login thread ending. | 2014-12-29 15:40:27 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:30 Starting TWS auto-login thread. | 2014-12-29 15:40:30 TWS auto-login thread ending. | 2014-12-29 15:40:31 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:31 Socket (19) | Shutdown and closed. | 2014-12-29 15:40:31 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:31 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:31 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:31 Disconnected from IB. | 2014-12-29 15:40:31 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:31 Starting TWS auto-login thread. | 2014-12-29 15:40:34 TWS auto-login thread ending. | 2014-12-29 15:40:35 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:36 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:37 Socket (20) | Shutdown and closed. | 2014-12-29 15:40:37 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:37 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:37 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:37 Disconnected from IB. | 2014-12-29 15:40:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:37 Starting TWS auto-login thread. | 2014-12-29 15:40:38 TWS auto-login thread ending. | 2014-12-29 15:40:39 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:42 Starting TWS auto-login thread. | 2014-12-29 15:40:42 TWS auto-login thread ending. | 2014-12-29 15:40:43 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:43 Socket (21) | Shutdown and closed. | 2014-12-29 15:40:43 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:43 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:43 Disconnected from IB. | 2014-12-29 15:40:43 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:43 Starting TWS auto-login thread. | 2014-12-29 15:40:46 TWS auto-login thread ending. | 2014-12-29 15:40:47 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:48 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:49 Socket (22) | Shutdown and closed. | 2014-12-29 15:40:49 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:49 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:49 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:49 Disconnected from IB. | 2014-12-29 15:40:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:49 Starting TWS auto-login thread. | 2014-12-29 15:40:50 TWS auto-login thread ending. | 2014-12-29 15:40:51 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:40:54 Starting TWS auto-login thread. | 2014-12-29 15:40:54 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:40:55 Socket (23) | Shutdown and closed. | 2014-12-29 15:40:55 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:40:55 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:40:55 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:40:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:40:55 Disconnected from IB. | 2014-12-29 15:40:55 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:40:55 TWS auto-login thread ending. | 2014-12-29 15:40:55 Starting TWS auto-login thread. | 2014-12-29 15:40:58 TWS auto-login thread ending. | 2014-12-29 15:40:59 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:00 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:01 Socket (24) | Shutdown and closed. | 2014-12-29 15:41:01 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:01 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:01 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:01 Disconnected from IB. | 2014-12-29 15:41:01 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:01 Starting TWS auto-login thread. | 2014-12-29 15:41:02 TWS auto-login thread ending. | 2014-12-29 15:41:03 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:06 Starting TWS auto-login thread. | 2014-12-29 15:41:06 TWS auto-login thread ending. | 2014-12-29 15:41:07 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:07 Socket (25) | Shutdown and closed. | 2014-12-29 15:41:07 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:07 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:07 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:07 Disconnected from IB. | 2014-12-29 15:41:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:07 Starting TWS auto-login thread. | 2014-12-29 15:41:10 TWS auto-login thread ending. | 2014-12-29 15:41:11 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:12 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:13 Socket (26) | Shutdown and closed. | 2014-12-29 15:41:13 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:13 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:13 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:13 Disconnected from IB. | 2014-12-29 15:41:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:13 Starting TWS auto-login thread. | 2014-12-29 15:41:14 TWS auto-login thread ending. | 2014-12-29 15:41:15 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:18 Starting TWS auto-login thread. | 2014-12-29 15:41:18 TWS auto-login thread ending. | 2014-12-29 15:41:19 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:19 Socket (27) | Shutdown and closed. | 2014-12-29 15:41:19 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:19 Disconnected from IB. | 2014-12-29 15:41:19 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:19 Starting TWS auto-login thread. | 2014-12-29 15:41:22 TWS auto-login thread ending. | 2014-12-29 15:41:23 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:24 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:25 Socket (28) | Shutdown and closed. | 2014-12-29 15:41:25 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:25 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:25 Disconnected from IB. | 2014-12-29 15:41:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:25 Starting TWS auto-login thread. | 2014-12-29 15:41:26 TWS auto-login thread ending. | 2014-12-29 15:41:27 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:30 Starting TWS auto-login thread. | 2014-12-29 15:41:30 TWS auto-login thread ending. | 2014-12-29 15:41:31 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:31 Socket (29) | Shutdown and closed. | 2014-12-29 15:41:31 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:31 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:31 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:31 Disconnected from IB. | 2014-12-29 15:41:31 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:31 Starting TWS auto-login thread. | 2014-12-29 15:41:34 TWS auto-login thread ending. | 2014-12-29 15:41:35 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:36 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:37 Socket (30) | Shutdown and closed. | 2014-12-29 15:41:37 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:37 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:37 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:37 Disconnected from IB. | 2014-12-29 15:41:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:37 Starting TWS auto-login thread. | 2014-12-29 15:41:38 TWS auto-login thread ending. | 2014-12-29 15:41:39 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:42 Starting TWS auto-login thread. | 2014-12-29 15:41:42 TWS auto-login thread ending. | 2014-12-29 15:41:43 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:43 Socket (31) | Shutdown and closed. | 2014-12-29 15:41:43 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:43 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:43 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:43 Disconnected from IB. | 2014-12-29 15:41:43 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:43 Starting TWS auto-login thread. | 2014-12-29 15:41:46 TWS auto-login thread ending. | 2014-12-29 15:41:47 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:41:48 Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-12-29 15:41:49 Socket (32) | Shutdown and closed. | 2014-12-29 15:41:49 Interactive Brokers | Failed to connect to the data and trade server. | 2014-12-29 15:41:49 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-12-29 15:41:49 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-29 15:41:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-29 15:41:49 Disconnected from IB. | 2014-12-29 15:41:49 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-29 15:41:49 Starting TWS auto-login thread. | 2014-12-29 15:41:50 TWS auto-login thread ending. | 2014-12-29 15:41:51 Starting TWS auto-login thread. | 2014-12-29 15:41:54 TWS auto-login thread ending. | 2014-12-29 15:41:55 Starting TWS auto-login thread. | 2014-12-29 15:41:58 TWS auto-login thread ending. | 2014-12-29 15:41:59 Starting TWS auto-login thread. | 2014-12-29 15:42:02 TWS auto-login thread ending. | 2014-12-29 15:42:03 Starting TWS auto-login thread. | 2014-12-29 15:42:06 TWS auto-login thread ending. | 2014-12-29 15:42:07 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-12-29 15:44:49 Socket (33) | Connected. | 2014-12-29 15:44:49 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2014-12-29 15:44:49 Interactive Brokers | TWS server version: 70 | 2014-12-29 15:44:49 Interactive Brokers | Connected. Waiting for account information. | 2014-12-29 15:44:49 IB Account information received. | 2014-12-29 15:44:49 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2014-12-29 15:44:49 Interactive Brokers | Connected to Demo or Simulated account. | 2014-12-29 15:44:49 Interactive Brokers | Not previously connected to Live account. | 2014-12-29 15:44:49 Interactive Brokers | Requesting Trade Positions for account: DU156967 | 2014-12-29 15:44:49 Next valid order ID: 1 | 2014-12-29 15:44:49 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2014-12-29 15:44:49 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2014-12-29 15:44:49 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2014-12-29 15:44:49 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2014-12-29 15:44:49 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2014-12-29 15:44:49 Next valid order ID: 1 | 2014-12-29 15:44:49 IB Account information received. | 2014-12-29 15:44:49 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2014-12-29 15:44:49 Interactive Brokers | Connected to Demo or Simulated account. | 2014-12-29 15:44:49 Interactive Brokers | Not previously connected to Live account. | 2014-12-29 15:44:49 Interactive Brokers | Received Trade Positions download end message for account DU156967 | 2014-12-29 15:44:49 Interactive Brokers | Starting real-time market data updates for: ES-201503-GLOBEX. ID: 1 | 2014-12-29 15:44:50 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2014-12-29 15:44:50 Interactive Brokers | Subscribing to Symbol: ES, SecType: FUT, Expiry: 201503, Exchange: GLOBEX, Currency: , Multiplier: | 2014-12-29 15:44:50 Intraday data recording state for symbol ES-201503-GLOBEX is set to download pending. | 2014-12-29 15:44:50 HD Request # 4 | Downloading Intraday chart data for ES-201503-GLOBEX to the file ES-201503-GLOBEX.scid. Service: cme | 2014-12-29 15:44:50 HD Request # 4 | Download start Date-Time: 2014-12-29 13:32:32.0 | 2014-12-29 15:44:50 HD Request # 4 | Using server: scdf1.sierracharts.com port 10149 | 2014-12-29 15:44:50 Interactive Brokers | Starting real-time market data updates for: ES-201409-GLOBEX. ID: 2 | 2014-12-29 15:44:50 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2014-12-29 15:44:50 Interactive Brokers | Subscribing to Symbol: ES, SecType: FUT, Expiry: 201409, Exchange: GLOBEX, Currency: , Multiplier: | 2014-12-29 15:44:50 Intraday data recording state for symbol ES-201409-GLOBEX is set to download pending. | 2014-12-29 15:44:50 Interactive Brokers | Starting real-time market data updates for: ES-201412-GLOBEX. ID: 3 | 2014-12-29 15:44:50 Subscribing to real-time True Data for symbol: ES SecType: FUT Exchange: GLOBEX Currency: | 2014-12-29 15:44:50 Interactive Brokers | Subscribing to Symbol: ES, SecType: FUT, Expiry: 201412, Exchange: GLOBEX, Currency: , Multiplier: | 2014-12-29 15:44:50 Symbol Error - ES-201409-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2014-12-29 15:44:50 Symbol Error - ES-201409-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2014-12-29 15:44:50 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-12-29 15:44:51 Symbol Error - ES-201412-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2014-12-29 15:44:51 Symbol Error - ES-201412-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2014-12-29 15:44:51 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2014-12-29 15:44:51 Socket (34) | Connected. | 2014-12-29 15:44:51 HD Request # 4 | Sending historical data logon request message. | 2014-12-29 15:44:51 Message from IB: Invalid Real-time Query:No market data permissions for GLOBEX FUT. IB Error Code: 420. Request ID: 140374604. | 2014-12-29 15:44:51 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-12-29 13:32:32. Record interval: 0. Symbol: ESH5 | 2014-12-29 15:44:51 HD Request # 4 | Decompressing data. | 2014-12-29 15:44:52 HD Request # 4 | Receiving Intraday data for ES-201503-GLOBEX starting at 2014-12-29 13:32:32 | 2014-12-29 15:44:52 HD Request # 4 | Timestamp of first Intraday data file record written: 2014-12-29 13:32:33 | 2014-12-29 15:44:52 Socket (34) | Shutdown and closed. | 2014-12-29 15:44:52 The network socket for historical data has been closed. | 2014-12-29 15:44:52 HD Request # 4 | Received 31207 records from 2014-12-29 13:32:32 to 2014-12-29 15:35:32 (2.1 hours) and wrote 31192 records for ES-201503-GLOBEX | 2014-12-29 15:44:53 HD Request # 4 | Intraday download COMPLETE for ES-201503-GLOBEX. Completion time: 3s. Unique request ID: 3 | 2014-12-29 15:44:53 Removed historical data download ID 3 | 2014-12-29 15:44:53 Real-time Intraday chart data file updates started for ES-201503-GLOBEX | 2014-12-29 15:44:53 Intraday data recording state for symbol ES-201503-GLOBEX is set to download pending. | 2014-12-29 15:44:53 HD Request # 5 | Downloading Intraday chart data for ES-201503-GLOBEX to the file ES-201503-GLOBEX.scid. Service: ib | 2014-12-29 15:44:53 HD Request # 5 | Download start Date-Time: 2014-12-29 15:35:32.0 | 2014-12-29 15:44:53 HD Request # 5 | Requesting a total of 0 days and 5361 seconds. | 2014-12-29 15:44:53 HD Request # 5 | IB Backfill - Seconds requested: 5361. Seconds Remaining: 0. | 2014-12-29 15:44:53 HD Request # 5 | Requesting 5361 Seconds of data at 30 secs with ending Date-Time at 2014-12-29 16:54:53 for ES-201503-GLOBEX | 2014-12-29 15:44:53 HD Request # 6 | Downloading Intraday chart data for ES-201409-GLOBEX to the file ES-201409-GLOBEX.scid. Service: cme | 2014-12-29 15:44:53 HD Request # 6 | Download start Date-Time: 2014-09-19 09:29:59.0 | 2014-12-29 15:44:53 HD Request # 6 | Using server: scdf2.sierracharts.com port 10149 | 2014-12-29 15:44:53 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-12-29 15:44:53 Socket (35) | Connected. | 2014-12-29 15:44:53 HD Request # 6 | Sending historical data logon request message. | 2014-12-29 15:44:53 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:29:59. Record interval: 0. Symbol: ESU4 | 2014-12-29 15:44:53 HD Request # 5 | Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 4. | 2014-12-29 15:44:53 HD Request # 6 | Decompressing data. | 2014-12-29 15:44:54 HD Request # 6 | Receiving Intraday data for ES-201409-GLOBEX starting at 2014-09-19 09:29:59 | 2014-12-29 15:44:54 Socket (35) | Shutdown and closed. | 2014-12-29 15:44:54 The network socket for historical data has been closed. | 2014-12-29 15:44:54 HD Request # 6 | Received 1 record from 2014-09-19 09:29:59 to 2014-09-19 09:29:59 (0.0 seconds) and wrote 0 records for ES-201409-GLOBEX | 2014-12-29 15:44:54 HD Request # 6 | Intraday download COMPLETE for ES-201409-GLOBEX. Completion time: 1s. Unique request ID: 4 | 2014-12-29 15:44:54 Removed historical data download ID 4 | 2014-12-29 15:44:54 Real-time Intraday chart data file updates started for ES-201409-GLOBEX | 2014-12-29 15:44:54 Interactive Brokers | Requesting historical order fills for account DU1*. | 2014-12-29 15:44:55 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201503-GLOBEX | 2014-12-29 15:44:55 HD Request # 5 | Intraday download COMPLETE for ES-201503-GLOBEX. Completion time: 2s. Unique request ID: 5 | 2014-12-29 15:44:55 Removed historical data download ID 5 | 2014-12-29 15:44:55 Real-time Intraday chart data file updates started for ES-201503-GLOBEX | 2014-12-29 15:44:55 Interactive Brokers | Received Open orders end message. | 2014-12-29 15:44:55 |
[2014-12-29 22:57:23] |
This is the problem: Message from IB: Invalid Real-time Query:No market data permissions for GLOBEX FUT. IB Error Code: 420. Request ID: 140374604. | 2014-12-29 15:44:51 http://www.sierrachart.com/index.php?page=doc/IB.php#MarketDataNotSubscribed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-30 11:32:40] |
I entered to the interactive brokers and see many options . right now in interactive brokers I see the ES future contract changes every second but through your app no. can you tell me for E mini contract and USD/EUR which are the only two I use in futures what shpudl be the addition I need. |
IB Subscription.docx - Attached On 2014-12-30 11:32:15 UTC - Size: 21.09 KB - 413 views Attachment Deleted. |
[2014-12-30 17:54:44] |
It is best to contact Interactive Brokers about this question. Let them know you want to be able to receive CME futures data and Forex data through the Trader Workstation API and what is the necessary exchange fee which has to be paid. You should not have any trouble receiving the cash Forex data and that does not require an exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-30 17:55:04
