Date/Time: Mon, 20 May 2024 21:11:00 +0000
Teletrader Data Feed | Loading Eurex Continuous Contracts
View Count: 1222
[2014-12-28 20:46:26] |
User10875 - Posts: 42 |
Hello, I am trying to load continuous contracts for Eurex futures with TeleTrader but I can´t find the correct symbols. According to information I have found on Teletraders website the symbol for a continuous FDAX must be something like %{413719};FGHJKMNQUVXZ1-;TR0D-2XM0;T1;PCC;AB with %{413719} being the FDAX future root symbol and the rest FGHJKMNQUVXZ1-;TR0D-2XM0;T1;PCC;AB the desired continuation settings. Unfortunately I am not able to retrieve the data. Can you help? Thanks. Kind regards SH. |
[2014-12-29 03:51:13] |
We have contacted TeleTrader about this. Definitely the symbol would not be nearly this complicated.
[2015-01-19 21:49:17] |
Have contacted TeleTrader support about this. Their support said that they can´t help as they do not know Sierra Chart very well. They asked me to contact you.... Kind regards SH. |
[2015-01-19 22:23:49] |
We have added Continuous Futures Contract support for TeleTrader. Refer to the version notes for 1222 here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1222 Let us know what other symbols you need rollover settings set up for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-19 22:23:58
